ADI-2 DAC FS
Ultra-Fidelity PCM/DSD 768 kHz DA Converter
ADI-2 DAC FS
Products
ADI-2 DAC FS
Ultra-fidelity PCM/DSD 768 kHz DA Converter
The ADI-2 DAC includes an improved SteadyClock, a fine-tuned to perfection analog circuitry, new MRC remote control, Extreme Power headphone output and a very special IEM output. It has all the bells and whistles that made the ADI-2 Pro famous, including its perfectly transparent sound signature and full DSP processing with Bass, Treble, Loudness, 5 Band Parametric EQ, Crossfeed and much more. With its simplified operation and stunning design it is the ideal center piece from home listening up to studio reference playback.
Connectivity and Features
RME USB 2.0
2 x Phones Output
Class Compliant Mode
1 x Line Output
2 x SPDIF Input
Remote
1 x Stereo Cinch
SteadyClock FS
DC-coupled Outputs
The ADI-2 DAC is the home and hi-fi optimized version of the ADI-2 Pro, a studio AD/DA converter of the highest quality. With many fresh ideas, innovative features and numerous useful functions, the ADI-2 DAC quickly became the reference. Thanks to its combination of high-end DA conversion with two exceptional headphone IEM outputs and a remote control, it has received countless enthusiastic reviews for its sound, flexibility, and technical capabilities.
The current version of the ADI-2 DAC comes with an extended remote control, a further improved DA conversion and an adapted analog output stage for even better noise and distortion values. To address the home and HiFi users, RME exchanged some of the Pro's studio features with typical home and HiFi ones. With an adapted feature set and much simplified operation RME proudly presents the ADI-2 DAC. Built on the technology, concept and features of the ADI-2 Pro, the DAC concentrates on DA conversion in top high-end quality, along with two exceptional headphone and IEM outputs.
ADI-2 DAC Features
The DAC
Packed into the compact half 19” format factor, this little gem is filled with the finest high-end electronics, offering a reference class conversion from SPDIF coaxial, SPDIF optical (ADAT compatible) and USB to RCA, XLR, TRS and mini-TRS.
As the most versatile DAC available, the ADI-2 DAC offers balanced/unbalanced analog I/Os, an Extreme Power headphone output, a super low noise IEM output, SteadyClock FS, 4-stage hardware output level control, DSP-based signal processing, external power supply operation, Class Compliant USB compatibility, sample rates up to 768 kHz as well as DSD playback. The SPDIF input signal can even be recorded via USB - as one would expect from RME the DAC is a true 2 channel Full Duplex audio interface.
Improving DA
The updated ADI-2 DAC uses ESS's ES9028Q2M in a special circuit variant developed by RME engineers that allows the chip to perform at its best. With noise levels of 123 dBA, distortion less than -120 dB, or THD+N of -116 dB, the device delivers outstanding measured values, and allows the IEM output to reach a sensational low noise level of -121 dBu. In addition, there is +2.5 dB of digital headroom, so that high intersample peaks do not produce any audible distortion. The reserve in volume setting results in a still undistorted analog output signal even at a volume setting of +2.5 dB.
There are no significant changes in operation, features and behavior compared to the predecessor, which is why neither appearance nor name have changed. All differences are explained in the detailed manual of the ADI-2 DAC.
Super Low Noise for IEM lovers
The headphone revolution not only brought headphones but also IEMs (in ear monitors) back into the attention of audiophiles and music lovers. Modern IEMs have a reference sound that easily competes with bulky over-ear headphones, making them not only a mobile alternative, but also an interesting solution in home.
Modern IEMs are extremely sensitive and operate on very low voltages. As a side effect they uncover the noise floor of the player, DAC or headphone amp. When RME developed its Extreme Power headphone stage the basic noise floor was taken care to be as low as possible. Which was then confirmed in many reviews (most black background…). Even when used with IEMs.
Still RME wanted to make sure that even the most sensitive IEM combined with the most sensitive listener receive the full dynamic range on playback. Also capable outputs like the Extreme Power ones are not fully safe against operating errors and might blow up ears or IEMs.
RME's solution: adding the most advanced IEM output imaginable as second phones connection to the front of the ADI-2 DAC. Its ground noise floor is an astounding 10 dB lower than the one of the Extreme Power output (black hole background…), output impedance is near zero Ohms, THD reaches new record lows, click-free on/off is included as well as volume ramp-up, and the sound quality with any IEM is just amazing. We're sure you will love it!
ADI-2 DAC IEM Output
Lights Out!
A studio converter with all lights off? Defective. But on a DAC it was one of the most often requested features from our ADI-2 Pro HiFi customers. Here we go: display, function keys, volume knob, even the standby button - they all go off after 10 seconds of no user operation when AutoDark is activated in the unit's menu. Touching any button or control will turn on all lights for 10 seconds. Using the remote AutoDark can also be switched off / on, and using any button on the remote turns lights on for 3 seconds. Once again: we're sure you will love it!
ADI-2 DAC DarkMode
More Outstanding Features
SteadyClock FS - Reference class Digital Clocking
Excellent performance in all clock modes and High Quality Analog Conversion to hear your mix as it is, with lowest jitter and highest jitter immunity.
Find out more
DigiCheck - The Secret Weapon of High Resolution Audio Measurements
RME Audio interfaces not only provide you with a professional digital audio interface, but also with a free available software tool: DigiCheck, for metering, testing, measuring and analyzing digital audio streams.
Find out More
ADI-2 Remote
The ADI-2 Remote software controller offers a seamless and intuitive interface for managing various parameters of the ADI- 2 series devices.
Find out More
New extended Multi-Remote Support (MRC)
The ADI-2 DAC comes with a remote that is not the usual cheap add-on. This nicely designed remote control has clearly labeled buttons, readable even in low light conditions without reading glasses, a nicely laid out button arrangement that is easy to remember, and perfect button ergonomics. Plus: It won't interfere with your ATV or other devices.
MRC Remote ADI-2 DAC
The ADI-2 DAC remote control provides buttons for standby on/off, volume, balance, bass and treble, input selection (optical, coaxial, USB), mute, on/off loudness, bass/treble and EQ. In addition, there are four programmable buttons that provide access to 32 different functions and commands for maximum flexibility. There is no other converter or comparable device with such a sophisticated, easy to use and at the same time versatile remote control!
Note for owners of the previous remote: the new MRC is also available separately as an accessory. It can be used with all ADI-2 DACs, even older ones, if they are equipped with the latest firmware (at least version FPGA 27, DSP 33).
SteadyClock FS
The ADI-2 DAC is the first device in RME's range with SteadyClock FS. There is not much to improve with SteadyClock, it has earned its accolades over years of flawless operation in numerous RME devices, guaranteeing that using the internal clock will produce exactly the same sound as when using an external one. SteadyClock highly rejects jitter and handles all digital interface formats in an exemplary way. That's why SteadyClock's design and behavior didn't change in the DAC.
With SteadyClock FS the focus was put on reducing the self jitter of SteadyClock to new lows, by improving its second, analog PLL circuit, and referencing both Direct Digital Synthesis and PLL to a low phase noise quartz crystal. The self jitter measured through DA conversion now reaches levels that usually are only available in master quartz clock mode, while SteadyClock still always runs in PLL mode - no matter if internal or external clock, sound is exactly the same (again). The low phase noise oscillator driving the updated circuit reaches jitter specs lower than a picosecond (ps), an area called FemtoSecond. Hence SteadyClock FS.
Bit Test
A bit test is used to check the playback path for unwanted changes in the playback data. Playback software can cut bits, add dither, or change the level - without these changes becoming noticed easily. A poorly programmed driver can manipulate bits, and a playback hardware could be both badly designed and defective (hanging bits, swapped bits). Even such features as proper channel assignment, left/right synchronicity and polarity can be tested by a well-made bit test.
With a bit test, such errors can be detected and - more importantly - excluded.
Bit Test Audio files (download)
Accessories
There are several items optional available for the ADI-2 DAC FS:
  • MRC - Multi-Remote-Control (Included)
  • NT-RME-2 Power supply for ADI-2 DAC. (Included)
    Robust and light-weight switching power supply, 100 V-240 V AC, 12 V 2 A DC. Lockable DC connector.
  • USB2M RME USB 2 cable, length 78” (2m) (Included)
Optical cables for SPDIF and ADAT operation:
  • OK0100PRO Optical cable, TOSLINK, 1 m (3.3 ft)
  • OK0200PRO Optical cable, TOSLINK, 2 m (6.6 ft)
  • OK0300PRO Optical cable, TOSLINK, 3 m (9.9 ft)
Specs
ADI-2 DAC FS
Digital Inputs
General
  • Lock Range: 28 kHz – 200 kHz
  • Jitter suppression: > 50 dB (2.4 kHz)
  • Jitter when synced to input signal: < 1 ns
  • Accepts Consumer and Professional format
SPDIF coaxial
  • 1 x RCA, according to IEC 60958
  • High-sensitivity input stage (< 0.3 Vpp)
  • AES/EBU compatible (AES3-1992)
SPDIF optical
  • 1 x optical, according to IEC 60958
  • ADAT compatible
Analog Outputs
XLR
  • Output level switchable +19 dBu, +13 dBu, +7 dBu, +1 dBu @ 0 dBFS
  • Signal-to-noise ratio (SNR) @ +7/+13/+19 dBu: 120 dB RMS unweighted, 123 dBA
  • Signal-to-noise ratio (SNR) @ +1 dBu: 117 dB RMS unweighted, 120 dBA
  • Frequency response @ 44.1 kHz, -0.1 dB: 0 Hz – 20.2 kHz
  • Frequency response @ 96 kHz, -0.5 dB: 0 Hz – 44.9 kHz
  • Frequency response @ 192 kHz, -1 dB: 0 Hz – 88 kHz
  • Frequency response @ 384 kHz, -1 dB: 0 Hz – 115 kHz
  • Frequency response @ 768 kHz, -3 dB: 0 Hz – 109 kHz
  • THD @ 0 dBFS: < -120 dB, 0.0001 %
  • THD+N @ 0 dBFS: -116 dB, 0.00016 %
  • Channel separation: > 120 dB
  • Output impedance: 200 Ohm
RCA
As output XLR, but:
  • Output: 6.3 mm TS jack, unbalanced
  • Output level 6 dB lower than XLR (-5 dBu to +13 dBu @ 0 dBFS)
  • Signal-to-noise ratio (SNR) @ +13 dBu: 120 dB RMS unweighted, 123 dBA
  • Signal-to-noise ratio (SNR) @ +1/+7 dBu: 116/119 dB RMS unw., 119/122 dBA
  • Signal-to-noise ratio (SNR) @ -5 dBu: 112 dB RMS unweighted, 114 dBA
  • Output impedance: 100 Ohm
Phones
As RCA, but:
  • Output: 6.3 mm TRS jack, unbalanced, stereo
  • Output impedance: 0.1 Ohm
  • Signal-to-noise ratio (SNR) @ +22 dBu: 120 dB RMS unweighted, 123 dBA
  • Signal-to-noise ratio (SNR) @ +7 dBu: 118 dB RMS unweighted, 121 dBA
  • Output level at 0 dBFS, High Power, load 100 Ohm or up: +22 dBu (10 V)
  • Output level at 0 dBFS, Low Power, load 8 Ohm or up: +7 dBu (1.73 V)
  • THD @ +18 dBu, 32 ohm load, 1.2 watts: -120 dB, 0.0001 %
  • THD+N @ + 18 dBu, 32 Ohm Load: -114 dB, 0.0002 %
  • THD @ +14 dBu, 16 Ohm load, 0.94 Watt: -110 dB, 0.0003 %
  • Max power @ 0.001% THD: 1.5 W per channel
IEM
As Phones, but:
  • Output level at 0 dBFS: -3 dBu, 0.55 V
  • Signal-to-noise ratio (SNR) @ -3 dBu: 118 dB RMS unweighted, 121 dBA
  • Max power, 8 Ohm, 0.001% THD: 40 mW per channel
Digital
  • Clocks: Internal, SPDIF In
  • Jitter suppression of external clocks: > 50 dB (2.4 kHz)
  • Effective clock jitter influence on DA conversion: near zero
  • PLL ensures zero dropout, even at more than 100 ns jitter
  • Additional Digital Bitclock PLL for trouble-free varispeed ADAT operation
  • Supported sample rates for external clocks: 28 kHz up to 200 kHz
  • Internally supported sample rates: 44.1 kHz up to 768 kHz
General
  • Included power supply: external switching PSU, 100 - 240 V AC, 2 A, 24 Watts
  • Standby power consumption: 120 mW (10 mA)
  • Idle power consumption: 7 Watts, Max. power consumption: 18 Watts
  • Idle current at 12 V: 570 mA (6.8 Watts)
  • Dimensions (WxHxD): 215 x 52 x 150 mm (8.5" x 2.05" x 5.9")
  • Weight: 1.0 kg ( 2.2 lbs)
  • Temperature range: +5° up to +50° Celsius (41° F up to 122°F)
  • Relative humidity: < 75%, non condensing
All specifications are subject to change without notice.
Back
Drivers
ADI-2 DAC FS
Flash Update
Release date
Download
Mac OS Flash Update Tool for MADIface XT/USB/Pro, OctaMic XTC, ADI-2 Pro Series & DAC, Digiface USB/AES/Dante/Ravenna, UFX II/III
Update to version: (*latest changes)
MADIface XT: USB 3/2 191, PCIe 56, DSP 42
MADIface USB, Hw Rev 6: 25
MADIface USB, Hw Rev 7: 101
MADIface Pro: 73
OctaMic XTC: USB 47, DSP 26
ADI-2/4 Pro SE: FPGA 72, DSP 40
ADI-2/4 Pro SE: FPGA 209, DSP 40
ADI-2 Pro Series: FPGA 267, DSP 128
ADI-2 DAC: FPGA 81, DSP 62
Digiface USB, Hw Rev X: 18
Digiface USB, Hw Rev G: 35
Fireface UFX II, Hw Rev A: USB 26, DSP 26, CC 15*
Fireface UFX II, Hw Rev E: USB 115, DSP 26, CC 112*
Fireface UFX II, Hw Rev 7: USB 206, DSP 26, CC 208*
Fireface UFX III: USB 20 DSP 21 CC 44*
Digiface Dante: 57*
Digiface Ravenna: 55
Digiface AES: USB 47, MCU 17, CC 11
Release date
2024-05-03
Windows Flash Update Tool for MADIface XT/USB/Pro, OctaMic XTC, ADI-2 Pro Series & DAC, Digiface USB, UFX II/III, UFX+, Digiface Dante, Digiface AVB
Update to firmware: (* latest change)
MADIface XT: USB 191 PCIe 56 DSP 42
MADIface USB: 25 (6), 101 (7)
MADIface Pro: 73
OctaMic XTC: 47/26
ADI-2 Pro series: FPGA 267, DSP 128
ADI-2 DAC series: FPGA 81, DSP 62
UFX II: USB 26 DSP 26 CC 15 (A), USB 115 DSP 26 CC 112 (E), USB 206 DSP 26 CC 208 (7)*
UFX+: USB 55 DSP 58 Thunderbolt 112 (A), USB 72 DSP 58 Thunderbolt 167 (E)*
Digiface USB: 18 (X), 35 (G)
Digiface AVB: 260*
Digiface Dante: 57*
Digiface AES: USB 47 MCU 17 CC 11
Release date
2024-05-03
Mac OS X
Release date
Download
MADIface Pro: 73
Digiface Dante: 57*
Release date
2024-05-03
Windows
Release date
Download
MADIface Pro: 73
OctaMic XTC: 47/26
Digiface AVB: 260*
Digiface Dante: 57*
Release date
2024-05-03
Windows 10
Release date
Download
Windows USB driver for MADIface XT / USB / Pro, Fireface UFX+ / UFX II / UFX III, OctaMic XTC, ADI-2 Pro/AE/FS/DAC, ADI-2/4 Pro, Digiface USB / AES / Dante / Ravenna
Version 0.9833, Windows 8 and up.
Release date
2024-01-23
Windows 11
Release date
Download
Release date
2024-01-23
Windows 7
Release date
Download
Windows 7 USB driver for MADIface XT / USB / Pro, Fireface UFX+ / UFX II / UFX III, OctaMic XTC, ADI-2 Pro/AE/FS/DAC, ADI-2/4 Pro, Digiface USB / AES / Dante / Ravenna
Version 0.9827, last driver version for Windows 7.
Release date
2023-09-13
Windows 8
Release date
Download
Release date
2024-01-23
Mac OS X
Release date
Download
ADI-2 Series Remote for macOS
Remote, backup and editing app for the ADI-2 series for macOS, v 2.1. Requires latest firmware update!
Release date
2024-03-23
ADI-2 Series Remote MIDI protocol (for developers)
For developers: the MIDI protocol  as used in the ADI-2 Remote. This is NOT an app!
Release date
2023-10-01
Windows
Release date
Download
Release date
2023-10-01
Windows 10
Release date
Download
ADI-2 Series Remote for Windows
Remote, backup and editing app for the ADI-2 series for Windows, v 2.1. Requires latest firmware update, and MADIface series USB driver 0.9827 or higher!
Release date
2024-03-23
Release date
2023-10-01
Windows 11
Release date
Download
Release date
2024-03-23
Release date
2023-10-01
Windows 7
Release date
Download
Release date
2023-10-01
Windows 8
Release date
Download
Release date
2023-10-01
Windows Vista
Release date
Download
Release date
2023-10-01
Windows XP SP2
Release date
Download
Release date
2023-10-01
Mac OS X
Release date
Download
DigiCheck NG macOS
Universal binary, runs natively on Intel and M1 machines. DigiCheck NG V 0.90 requires macOS 10.13 (High Sierra) or up.
Release date
2023-06-27
Windows
Release date
Download
DIGICheck 5.96 Win
Release date
2023-01-13
Download
dc_596_win.zip
Back
Manuals
ADI-2 DAC FS
Product
Description
Download PDF
ADI-2 DAC
ADI-2 DAC manual, version 1.8, 09/2019
ADI-2 DAC (new remote)
ADI-2 DAC manual, version 3.3, 11/2023
ADI-2 Remote
ADI-2 Remote manual, version 2.0, 03/2024
Product Images
Media Material
Additional Downloads
Back
